How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
It Auto inserts parts. But not T-junction.
Does anyone know insert part or what is wrong with the underlying 3D sketch?
@MatsNorway1
Branch fittings are not automatically generated in Tube & Pipe. Are you using the Routing sketch tool, or is this a Derived 3D Sketch? In either case, branch fittings need to be placed manually.
Did your question get successfully answered? Then just click on the 'Accept solution' button. Thanks and Enjoy!
Chris Benner
Industry Community Manager – Design & Manufacturing
From content senter?. its a derived 3D sketch.
Where do i pick pipe dia.
MatsNorway:
In the route, place a node in the bottom pipe where the two pipes would intersect. Exit the route. A coupling should automatically be placed at the node. Then, use a "Replace from Content Center" on the coupling and select the desired tee. The result should be a tee at this point with the branch aligned with the intersecting pipe. I have done this multiple times and it (usually) works the way I expect.
Let me know if you have any questions!
Chris:
Tube and Pipe is a very powerful tool (I use it daily in my industry) however with some work it could be much more so. The ability to define a tee mid-route is just one example, I could think of many more. Are there any plans in the near future to update the T&P module?
Thanks!
@matthew.hansche Hello! Take a look at the Inventor Ideas forum, there are several Tube & Pipe Ideas over the years in there that you could vote for... some of them by a user whose name may look familiar. 😉
Chris Benner
@MatsNorway1
I just did a test, and determined (I should have already known), that fittings cannot be inserted into a Derived Route. Your best bet would be to use the Route sketching tool in Tube & Pipe to sketch your routes.
Chris Benner
How to buy
Type a product name
