Symbol for view/section rotation
Sergey_Dukman
Sergey_Dukman
Hello everyone.
Do we a symbol showing the direction and the value of the angle of rotation after the section or view has been rotated?
Replies (11)
andrewiv
Not sure if I understand your question.  Can you provide more details?
Andrew In’t Veld
Designer / CAD Administrator
mdavis22569
Thinking he wants it to be something like ... Section A-A (@45 degrees) for example
Mike Davis
Sergey_Dukman
Yes, it is what I've meant.
Sergey
mdavis22569
I think this would be more of a custom or iLogic type note....
Mike Davis
Sergey_Dukman
I didn't quite get it.
Would you, please, explain it in more detailed fashion?
Sergey
Sergey_Dukman
If I want to make a section of a view and then rotate this section by an angle (rick click on the section and then choose "rotate"), there is a need of showing on the drawing that the section has been rotated clockwise/counterclockwise by a certain angle. So there must be a marker/option showing this. Hopefully it is more clear for you.
Sergey
mdavis22569
Oh I get it ... I use to do it manually back in the day doing Car related designs ...
Just not sure it's possible without some coding. I can't think of anything out of the box that will do it.
Mike Davis
Sergey_Dukman
I understand.
Anyway I found it strange that Inventor doesn't have this option. I have to do it manually which is inconvenient.
Some other 3D applications (NX) does have it. Maybe creators of Autodesk Inventor should consider making such a marker available on future Inventor releases.
Sergey
Sergey_Dukman
Conclusion:
There is no any option that can show rotation of a section or a view automatically on a drawing.
The only way to do it is make a mark manually or by some coding.
mdavis22569
Share an NX example
It might be something the Idea's station as well.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Mike Davis
Sergey_Dukman
I posted it on the suggested thread.
Sergey
