Material Library Missing [Inventor 2021]
Hi when i attempt to load up the material editor it says i am missing the material library.
I went to this link to manually add them:
https://knowledge.autodesk.com/support/infraworks/learn-explore/caas/CloudHelp/cloudhelp/ENU/IWGetti...
Except this only goes to the 2020 year.
I also tried booting up the installer but it doesn't give any option to add these.
Any help?
leowarren34
Hi @Anonymous,
Can you upload an screenshot of your installer on the select components screen?
Also run a search through your system for MaterialLibrary2021.msi: (Paths may/will be different)
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
