Hi, I accidently made all my dimensions in Imperial and I need them in metric. I tried switching the style and updating it and I tried updating the document settings. I uploaded the drawing and the part file that it is dimensioning. Any help would be really great.
P.S I know the drawing is a mess. I'm new to this.
Solved by HenryCarlson124. Go to Solution.
Solved by japike. Go to Solution.
You can right click on a dimension and select Edit Dimension Style then change the units in the dialog that comes up.
Thank you! Is there a way to change all the dimensions at once? I have like 30 dimensions and want to change them all at once.
@HenryCarlson124 Do what was suggested above.. That will change all dimensions that are controlled by that style..
