Sweep vs extrude: Sweep block evreything not extract, why ?
Message 1 of 18
Hi
I am having an issue:
- When I sweep:
After that I cant start a 2d sketch on the created surface
After I cant Shell the value I want
- With the same objects, if I Extrude instead of sweeping:
I can start another 2d Sketch by selecting the extruded surface
I can Shell the value i want
Sorry in advance if it's a stupid problem, I am a beginner
I attach the file with the surface and the path to sweep, then try to add a 2d sketch on the bottom face
Thanks all
Replies (17)
Message 2 of 18
WHolzwarth
Looks like a bug.
I've added some dimensions and constraints to your Sketch2, and tried the whole thing without fillets in Sketch2.
Sweeping was done, but after that no fillets could be applied. Trying to shell the simpler geometry failed as well.
After that I made a STEP of it, and re-imported it to 2016. Fillets and shell could be done now.
Walter
Walter Holzwarth
Message 3 of 18
Thanks you for fixing the model
I dont know if I can ask the question here or if I need another thread:
In the project you just modified:
Why I Can't 2D sketch against the face created by a Sweep ?
Thanks again
Message 4 of 18
JDMather
Attach your extruded example and your swept example.
Indicate which face you want to do the 2D sketch (must be a planar face).
I am having trouble figuring out your true design intent as the sketches are not fully defined.
I suspect that if you really want a sweep that the profile should be sketched perpendicular to the path (it currently isn't).
Message 5 of 18
Message 6 of 18
JDMather
Why didn't you attach the image files here?
Message 7 of 18
We can only attach 3 files maximum to a post 😞
Message 8 of 18
JDMather
I don't go to third party sites like the one you linked.
I have had bad experience with silent install of malware in the background.
What happens if you -
put all files into a folder,
right click on that folder and select Send to Compressed (zipped) Folder,
and attach the resulting *.zip file here (1 file)?
or
upload to your A360 drive and provide link here?
Message 9 of 18
Sorry about that
No problem, I did the attachment via ZIP files 🙂
Message 10 of 18
Sorry about that, this is the correct Image archive
Message 11 of 18
JDMather
This would be a complex design for a beginner.
It is not a extrusion.
Sketches should be fully defined.
Sweep profile should be perpendicular to sweep path.
I woud avoid splines if possible.
Message 12 of 18
Thanks you for reviewing the pictures
So you think I am not in the correct path for doing it.
I have already spent maybe 60 hours on it and still stuck
I would be really gratefull if you could give me some general guidance, advices, on how to do it. I will begin from scratch again (for the 50th time)
Thanks you very much you are really helpfull
Message 13 of 18
rdyson
See if this gives you any ideas.
PDSU 2016
Message 14 of 18
That's really nice thanks you !
It looks like mine, with another method, I really like it's very elegant !
But the problem stays the same, The big big issue I am trying to solve for days, is to create this shelled extrusion:
There is multiple difficulties for this back "extrusion" holding the circles holes:
1 - It follows the front bezel shape
2 - It also follows the side curve
3 - It's has not the same dimension , it has a "Draft" shape (large on the top, thin on the bottom)
Even with your model I did not find any way do it
I am really sorry for using your precious time for that
Thanks again guys
Message 15 of 18
WHolzwarth
After looking at your pictures, I'd start like that.
Walter
Walter Holzwarth
Message 16 of 18
rdyson
Attach your progress to date and explain what you next step will be.
PDSU 2016
Message 17 of 18
Oh my goodness that's exactly what I was looking for !
I really appreciate your help on this one, and this push me to learn more and more about Autodesk tooling
I am analyzing the steps to completely understand how you did it
Thanks you again
Message 18 of 18
I will !
My next step is analyze the file modified by wh, then I gonna try to finish the bezel
I began the second part over the weekend and already spent 20 hours on it, it's very challenging but so interesting
