- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi everyone
I have a conundrum here. I am authoring a Bowden Cable assembly driven via a form.
In short the user keys in several parameters from the destination model such as inner distance between mounting brackets, axial offset between each end, both mounting bracket thicknesses, free length at each end and each end threaded length... and it works great... A user can copy design the part type if a few parameters and have a Bowden Cable representation that they can drop straight into their larger assembly model.
However, what I now wish to do is spit out a drawing with parameters that we can send to our cable supplier and this is where I am running into difficulty.
The inner cable is made from 3 sections -straight sectioned free end lengths at each and and an inner sweep. I have two solids in the part - Inner cable and outer sheath. This ipt is then dropped into a Bowden assembly model containing the cable end jam nuts and bracket mounting nuts. It's not a correct assy per say as it only needs to visually represent the real purchased part.
So what I need to do is calculate (via iLogic) the inner and outer cable length. I had a look over the forum and saw one method for obtaining the sweep length here:
https://forums.autodesk.com/t5/inventor-forum/loop-length/td-p/3121626
However the total fx length gets messed up when I try to add my straight sections onto the total length - My total length when displayed in a messagebox seems to be out by a factor of '/10' before I ad my straight sections on.
Perhaps another way to implement it to to get the volume of the solids and divide out by the cable Ø and similar for the outer cable but I have no idea programatically how to query individual solid body volumes.
Vault Professional 2025.3
