sweep help
sweep help
sweep help
I need help making a sweep. I have attached the ipt file I am working with. I need "sketch 6" to be swept along the outside of the part making it look bubbled. can anyone help? this is in inventor 2016
Sofia.Xanthopoulou
Hi @Anonymous,
please check your model. At least at this point your sweeping path will not be correct because the model has something like interference. If your path is "clean", sweeping should not be a problem.sweep_path.png
Regards
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Sofia.Xanthopoulou
Hi @Anonymous and Happy New Year Smiley Happy
Have you cleaned up the model? Did it work? Please share your experience on this with all readers - much appreciated Smiley Wink
If you need further assistance on this, please continue the conversation
Please create a new thread for other questions.
