SVG lines to surface
norman.nabhan
norman.nabhan
Hi. I have an SVG file with a sketched window (see attachment). From this image I want to create a stamp. Via Inkscape I export the image as DXF. I get the image as a sketch placed on a surface. From this point, unfortunately, as a novice, I do not know how to extrude the lines. I have to make closed surfaces with a certain thickness out of the lines right? What is the best way to approach the problem?
Thanks and many greetings!
Gabriel_Watson
If by stamp you mean an emboss/engraving, then you will need to make sure that your sketch has closed loops. I often had to import from AutoCAD some vector logos for drawing templates in Inventor, and had to fix those in AutoCAD before importing. You should turn all lines into p-lines and join them, which helps making sure the image is "watertight". Let me know if you need more help on this.
-niels-
This is quick and dirty, but i opened up your svg in Illustrator and expanded the lines so i got outlines instead of the single lines (not sure if Inkscape has a similar function, but i'd expect it to).
I then exported it to dwg and imported it into an Inventor.
On the first go it was too small for inventor to properly recognize the contours, so i scaled it up a bit.
It worked better, but still had a line that didn't get recognized.
I extruded that as a surface and used patch and stitch to close the profile.
If you clean up the svg before exporting to inventor you can probably circumvent that issue, i just left everything as it was but there are a lot of internal lines that can be removed.
Attached is my IV2021 file and the exported dwg.
Hope it helps.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
norman.nabhan
Hello, thank you for your detailed answers! Then I'll find out how to do it in Inkscape. I already had such a similar idea, but didn't know how to do it actually. I guess I'd better ask in an Inkscape forum for that.
