Greetings
I am new to learning Surfaces and am in need of some help with a part i am creating.I cannot seem to join the surfaces together to create a solid.Any help appreciated
Cheers
Terry , INV 2012
Hi
Its something like this that you want?
this is only one of several ways...
Hi Maria
Thanks for the responce.Yes that is the shape i was seeking.The only issue i have with it is that when i went to apply a .1mm fillet it would not accept.Could it be where it joins to the half ball shapes as there is a slight edge.Any suggestions.
Thanks again
Terry
I could only get it to work at .15mm and not at .1mm or below
Terry
Dont apply all the fillets at once. The sequence here its really important.
It occured to me that this part might be simplfied not using surfaces. (see attached)
1 master sketch, 7 features.
