surface
surface
huseyinagtas
surface
huseyinagtas
Hello, I want to use the role I drew like a cam.
1- how to make a surface known as surface1 into a single piece.
2- how to convert lines to splines.
JonathanKruger
I am not sure I follow but you could thicken the surface and toggle the surface to be not visible afterwards. Could you explain more on what you want to achieve as using extrude would be more efficient
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
swalton
Surface 1 is a single surface.  Inventor only sees one object when I select it with the Stitch tool.
Inventor will not hide the lines at the at the tangent edges.
Is your goal to have a G2 curvature at each direction change?
See https://forums.autodesk.com/t5/inventor-forum/continuity-types-g0-g1-g2/td-p/10916385
 I don't believe that there is a tool to convert lines or arcs to splines.  Instead I would create a new sketch, and trace the geometry with the spline tool.
You might find some useful information from the Cam Design tools.  https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-88D2391B-20CD-421B-A390-4347CA464B0A
Steve Walton
Inventor 2025
Vault Professional 2025
huseyinagtas
I want to give a mate like in the video
blandb
Typically "Translational" constraint will do cam/follower type movements.
Autodesk Certified Professional
JDMather
You have a Spring Force.
Environments>Dynamic Simulation 2D Contact Joint and Spring Force Joint.
(Same as SolidWorks Advanced Motion.)
Examine the Attached assembly (I only partially set up the Dynamic Simulation).
https://www.youtube.com/playlist?list=PLp5izJt_zvN08mpY4UcYrzJV2N6QOLAIR
https://www.youtube.com/playlist?list=PLp5izJt_zvN0GnwEUFR1zE06nQvDAWxz2
huseyinagtas
thank you very much for your help
and amazing tutorial videos very good now i understand better
