Surface to Solid
Surface to Solid
lhoggeth
Message 1 of 10
Surface to Solid
lhoggeth
Hi, hope you can help me.
How do I convert the surface model to solid? I need to store this model into the library....
Attached step file.
Many thanks
Replies (9)
Message 2 of 10
CCarreiras
Hi!
Select all the surfaces, and use the STITCH tool.
If the model is correct, and there are no gaps in the surfaces, it will become solid.
CCarreiras
Message 3 of 10
JDMather
@lhoggeth
I do not see a STEP file attached?
Message 4 of 10
lhoggeth
I'm not able to do this... please see below.  Any ideas? Thanks
It says - Create stitch failed
Stitch Surface1: could not build stitch surface
Message 5 of 10
lhoggeth
Trying again this time - attached.  Thanks.
Message 6 of 10
JDMather
There are quite a few missing surfaces in the geometry - does not form a "watertight" envelope.
Will require repair.
@lhoggeth
What version of Inventor are you using?
Message 7 of 10
lhoggeth
Inventor 2022.
Many thanks
Message 8 of 10
JDMather
I removed the text, logo and patched some holes.
See Attached...
Message 9 of 10
lhoggeth
Many thanks 🙂
Message 10 of 10
CCarreiras
The part has some gaps (lack of surfaces) in some places, here's an example:
after close those gaps, it works.... check the attached file...
CCarreiras
