Suppressing an element in an assembly's pattern using Model States
Ray_Feiler
Advisor Advisor
Ray_Feiler
johnsonshiue
Hi Ray,
Let me share some background information about this particular item. Originally, suppressing a pattern element (component or feature) per Model State was indeed in scope. However, due to internal testing, we found out there was serious performance and capacity concern. The behavioral model particularly with the variable number of pattern instances can be very complicated. As a result, the decision was to make it a factory scope edit for the time being.
Many thanks!
Software Test Engineer
pcrawley
If you want a solution while waiting on Idea Station votes, you can suppress pattern elements using iLogic and trigger the code with a Model State change.
See here for the element suppression code: https://forums.autodesk.com/t5/inventor-forum/cannot-suppress-pattern-element-using-ilogic/m-p/35759...
Peter
johnsonshiue
Hi Peter,
This is a very interesting workaround. The catch is that you still cannot show two Model States with different pattern element suppress status. You will need two iam files to do that. It cannot be within one iam file.
Many thanks!
pcrawley
Good point!  It may not be the 'answer' the OP is looking for after all.
Peter
