Superscript/subscript not displaying correctly
jasons
jasons
I am attempting to insert some greek symbols with sub and superscript using the sketch environment within a idw. When editing the text, it looks fine, as below
but, when I close the text editor, the text sits on one line, as below
I know this is a fairly trivial issue, but I would like to correct it. Can anybody assist?
Thanks, Jason
jasons
Should have mentioned, I am using Inventor 2024
Alexander_Chernikov
Have you tried the "Stack" option?
Inventor 2024.2.1?
Can you attach a file with this problem?
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
tpaulk75
I am having the exact same issue in Inventor 2025. I have tried the stack issue.
tpaulk75
I meant to say stack option, not stack issue.
