Subtract Part from another in assembly, pattern.
Alexrose1942
Message 1 of 11
Alexrose1942
Hi
using this tutorial I learned how to subtract one solid from another on assembly environment, I wonder if anyone have a creative way to do this with pattern,  the shelves in the image should be in different heights  that ill have the exact dimension to cut the hole in them . (6 shelves total)
Thanks!
Replies (10)
Message 2 of 11
-niels-
This might not be the best example, but i'd probably build it as a multibody part and then push out the individual parts to an assembly.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 11
WHolzwarth
Here's a similar sample using iCopy, origin from Autodesk. It seems to be no more present for download.
Very interesting video about iCopy from admaiora is here:
https://www.youtube.com/watch?v=P_m_jQVkqHU
Walter
Walter Holzwarth
Message 4 of 11
Alexrose1942
Video is unavailable.. anyway not sure where to start with icopy?? haven't  found any good tutor for dummies.
icopy means i will use a sketch (as an assembly) , as sub-assembly in case sizes differ from one another through a specified path. how do i start consider the only that change is the holes in the shelf, and not shelf sizes?
Message 5 of 11
WHolzwarth
Video from admaiora could be started right now here.
You can find the above mentioned sample here:
C:\Users\Public\Documents\Autodesk\Inventor 201x\Samples\Models\Fabrication\Shelf_Target
201x= Any Inventor release since 2011
Walter
Walter Holzwarth
Message 6 of 11
Alexrose1942
Message 7 of 11
Alexrose1942
I'm not sure icopy can do this, as the hole is a feature being subtracted..
any new ideas?
Message 8 of 11
Curtis_Waguespack
Hi Alexrose1942,
Did you explore the suggestion that @-niels- gave you? I think that is the method that I would use.
I hope this helps.
Curtis
Message 9 of 11
Alexrose1942
unable to open his .ipt file in 2015 version, but ill try to explore it.
i was looking more for a pattern solution..
Message 10 of 11
Curtis_Waguespack
Hi Alexrose1942,
Attached is a simple example file created in Inventor 2015 for you to look at. You can use this file to explore the Make Components tool, which allows you to "write out" all of the solids as derived parts and it places them into an assembly. Then you can make updates to this original part file and it will update all of the parts and the assembly.
I hope this helps.
Curtis
Message 11 of 11
Alexrose1942
That's a great and simple solution !
Thank you !
