Subassembly Appearance Disappears in Assembly
logan_armagost
logan_armagost
Apologies if this has already been addressed. I was not able to find a thread that did so.
Here is my situation:
I have a part file (Part A) with a material and corresponding appearance applied. I put the part A in an assembly file (Assembly 1) and then I click the part and change the appearance to another color. This works as expected. The color of the part changes in the context of Assembly 1 but stays how it was before when the part is opened on its own. When I place Assembly 1 into another assembly (call it Assembly 2), I would expect it to retain its appearance settings. After all, I'm placing Assembly 1 (where I made the change), not Part A. However, this is not the behavior I'm getting. The appearance of Part A inside Assembly 1 when placed in Assembly 2 reverts back to the original color of the standalone part. Why? Is it possible to have sub-assembly appearance overrides permeate when placed in another assembly? I would expect them to until another override is made in the higher level assembly file, but this doesn't seem to be the case.
kacper.suchomski
Hi
The appearance of an assembly is local.
You can use a view representation and insert a subassembly in the style set in that representation.
Kacper Suchomski
logan_armagost
So I need to save the appearance setting in Assembly 1 as a design view representation, then activate that from the context of Assembly 2? Is there a way to save the appearance in the default design view so it always comes in as the correct appearance?
kacper.suchomski
Nope. As I mentioned, appearance overrides are by default a local feature.
Kacper Suchomski
logan_armagost
Okay, thank you. Do you know where I can submit this as a suggestion for future improvement?
kacper.suchomski
https://forums.autodesk.com/t5/inventor-ideas/idb-p/inventor-ideas-en/tab/most-recent
Kacper Suchomski
johnsonshiue
Hi Logan,
The Design View Rep behaviors can be subtly confusing. I think there should be a way to yield the desirable behavior. If possible, please share an example that illustrates the issue. I would like to take a look  to understand the issue better.
Many thanks!
Software Test Engineer
