Hello all,
Couldn't find anyone else with this problem, so it might be my own obliviousness. But hope someone can help me.
I recently upgraded to Inventor 2021 (Win10). All my templates were migrated correctly (or so it seemed). But I have a problem now. Whenever I open a new IDW from my own templates with 'create a new file', it ignores the styles and standards and uses the "factory" default. When I open the template from the template folder directly it shows me the style and standard settings I adjusted myself (precision & trailing zeros E.g.). Anyone knows the solution?
Greetings,
Sven
Hi Sven,
this behavior is correct, create a template involves a project and the ability to read/write a library.
Admaiora
Did you upgrade your project file? Making sure that has all of the styles, material and folders pointing to the correct locations?
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2020
Thanks all for your reply, it triggered me to search in the right direction for me. In the end I opened the template file, went to the style editor, right-clicked the active standard and selected "update style". Problem solved, thanks!
Greetings,
Sven
