Hey all,
I am wondering if it is possible to do a style update (or style update check) upon open of a drawing?
The example would be that I have stuff made from way back that the colors/dimension sytles ect dont match the current standard and upon opening a file where they are not current, it would either prompt to update immediatly OR update automatically with no prompting (preferred method).
I am doing a massive amount of updates from old files recently and to save myself 1 - 3 clicks per drawing would be wonderful.
tks! 🙂
See if this thread helps you.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Thanks for that. Seems like the mCAD way might be the answer...if only I could find the download link? I looked in the App Exchange (maybe I am using wrong wording when I search?)...or is it somewhere else?
tks!
Ah! That would do it, not registered so it wont show... I will register to try it out. 🙂
