Style of existing hose route in Tube and Pipe does not update
Hello.
I have a project with some existing Tube and Piping routes, but I need to change the hose style. Given that sizes lower than 1/4 were not available, I had to create my own hose style and publish it to content editor.
The hose style works fine for newly created routes, but it doesn't allow me to select it to change it on existing ones in the lowest part of the hose route hierarchy.
Figure 1 and 2: The created style doesn't show on list
My style is called "Vent_small" and as you can see in the image below, it's already created and imported into the Tube and Pipe Styles editor.
Figure 3: The style is already created and imported to the Styles editor.
The higher parts in the Tube and Pipe hierarchy allow me to select it but take no effect on changing the existing hose.
Figure 4: Hierarchy of my Tube and Pipe.
That is, in this hierarchy, I'm able to select it in Run 09, Flexible Hose 09, but not in Hose09. As you can see in figure 5, if the Flexible Hose 09 is active, I'm able to select the style, but it takes no effect.
Figure 5: Pipe run menu under the Flexible Hose 09 allows me to select the style (Vent_small)
So, to summarize, two questions: Why does the style change take no effect on the existing hose, and, why can't I select if I open the hose itself?
