Inventor Forum
Style manager error 2025
5 REPLIES 5
trym_holmedal
235 Views, 5 Replies
Any updates on the Style Manager Error in Inventor 2025? Prevents me from migrating the Style library.
See:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Unable-to-start-In...
5 REPLIES 5
Hi! The defect INVGEN-77127 has been fixed on the coming 2025.1 update. It will be available very soon. Please install the update and report back your findings.
Many thanks!
Software Test Engineer
I installed the 2025.1 update but it did not help.
Hi! For your case, you may need to manually correct the following file.
Close Inventor. Go to File Explorer and browse to the following file and edit it. Change the version from 2 to 3.
C:\Program Files\Autodesk\Inventor 2025\Bin\_NewStylesLibrary\StudioScene.xml
Does it work better now?
Many thanks!
It is already version 3:
<StudioScene Version="3" />
rui_wang
in reply to: trym_holmedal
@trym_holmedal
Could you please help to share your entire design data folder with us for more investigation?
You can reach me out via email, rui.wang@autodesk.com
Btw, could you please have a try with below steps?
  1. Reset Inventor 2025 via Reset Utility, then start Inventor 2025.
  2. Run command line, "C:\Program Files\Autodesk\Inventor 2025\Bin\Inventor.exe" /install.
  3. Start Style Library Manager.
