Countless times I've researched this problem, and I can NOT get it to work.
The above link explains step by step how to fix this problem, which I'm having because I changed it to where Bend Centerlines don't show up. I want the definitions in my template to be what's used every time I open up my template in a new project. I followed these steps, listed below, but then I create a new drawing with my template and it's STILL giving me the same prompt/error. Can anyone please help me out? This is bugging me to no end.
If the template contains the correct style definition, then overwrite the style library definition:
- In the Project setting, set Use Style Library to Read-Write. (Changing Inventor Styles Library from Read-Only to Read-Write)
- Open the template file from Open dialog box (DO NOT start a new document by selecting the template).
- Ensure that the style definitions are correct. (For example, you see a correct material or color of created component).
- In the Inventor Ribbon menu, go to Manage > Styles and Standards. Execute Save.
- You see a list of style differences between Design Data and Template.
- Select Yes or No for 'Save to Library?' - they'll overwrite the style library. This CANNOT be undone.
- Click OK to complete the update. ( Message will disappear when you do not see any style differences.)
