Style conflict issue inventor 2017 (FDS)
3DAli
Message 1 of 68
3DAli
Hi there,
here is what I am experiencing with my standard templates when I switch to anything other than "standard".
I keep updating the style in my templates, and this keeps showing up!!!!
any idea how to resolve this?
Replies (67)
Message 41 of 68
Sofia.Xanthopoulou
Happy New Year to you, too @3DAli Smiley Happy
Indeed this is not good news. Can you please tell me which update you ran? Can you roll it back?
And you get the same messages? Do you switch projects? Does it happen in all your Inventor projects?
I am so sorry that you run into this again. But if this behavior is reproducible we have to figure out what triggers it.
Message 42 of 68
3DAli
Hi Sophia,
as far as the update goes, its Build:233,Release: 2017.3 Update - Date : Mon 10/31/2016
in terms of inventor projects, I am using vault, so I only have one project that manages the entire work-space with unique file naming system pushed through vault.
this is puzzling me as well and I totally understand your point to reproduce it and diagnose it from there, but I just dont know how. I can give you a clue and it might help Autodesk team with identifying where the issue is coming from,
if I open my standard(mm).ipt , go to document settings, change units back to "in" and "lb" from "mm" and "kg", save the file and close it, the error message disappears, so whatever it is, units causes that "default modelling" mismatch in style. as soon as I change the units back to metric, it pops up. to be honest with you I cant think of anything else that I have done after we fixed the issue and I also contacted our re seller and let them know.
Having said that, the product is running fine otherwise, I can shut the message up for the session and it wont bug me anymore, but I just wanted to contribute to a have a better , more reliable problem free product in future versions.
Sincerely
Ali
Message 43 of 68
Sofia.Xanthopoulou
Hi @3DAli,
just wanted to inform you that I haven't forgotten about this thread. I just couldn't get any new information yet.
And I guess your issue hasn't disappeared, right? Smiley Embarassed
Regards
Message 44 of 68
3DAli
Hi Sofia,
Thank you for being supportive, yes the issue still persists, I even
uninstalled the entire suite and reinstalled it fresh and the problem exist
from the get go.
Regards
Ali
Message 45 of 68
Sofia.Xanthopoulou
Hi @3DAli,
do you use multiple language on your machine or Inventor? There might be a connection. I am on to something, but I need to verify.
Regards
Message 46 of 68
3DAli
my Inventor is only on English, I have Persian installed on my windows, so I can type in both languages
Message 47 of 68
Sofia.Xanthopoulou
And all communication inside Inventor is with Latin characters?
Regards
Message 48 of 68
3DAli
YES 100%
Message 49 of 68
Sofia.Xanthopoulou
Thank you @3DAli
And my search will go on... Smiley Wink
Thank you for your patience.
Regards
Message 50 of 68
3DAli
I see myself on the same side as you are, so no worries, we will tackle this,
thank you Sophia 🙂
Message 51 of 68
Did this issue ever get solved? It is marked as solved, but I don't see a solution.
I agree; I've been having this issue for years with Inventor, to the point where I feel I'm going crazy. Open the part template, save the styles, save the part template, open a part, get the exact message again. Time and time again.
Absolute crap!!!
Message 52 of 68
3DAli
No Paul , still the same in 2019 ! I gave up on it , I just use my standard temp. and I change the units manually!
this is a fresh installation on a fresh computer on Windows 10, so its definitely a flaw in the software and has nothing to do with my copy.
Message 53 of 68
It's comforting to know I'm not the only one who has endured the pain Ali. Smiley Sad
Reckon I've gone through that process at least a couple of hundred times.
New install on new laptop myself, hence why I asked the question.
May go and find a small padded cell right now then...
Message 54 of 68
johnsonshiue
Hi Guys,
The warning dialog indicates that the some styles stored in the Standard (mm).ipt are different than the same named definitions in Styles Library. Have you shared the template you are using here? If not, please share.
Many thanks!
Software Test Engineer
Message 55 of 68
More than happy to be taught a lesson on this one.
In fact; I'd be over the moon...
Message 56 of 68
3DAli
Templates attached,hopefully the worm is lying somewhere in here and you guys can catch it
Thank you Johnson Smiley Happy
Message 57 of 68
Mark.Lancaster
@johnsonshiue
I will tell you that I reported this back 2 years ago while assisting a user..  At that time it was thought the issue was related to the templates being located on the user's network and not in the default/standard location.  However we never found a solution and the user redid their Inventor installation since they were switching to a new machine and the issue never returned for them.
Mark Lancaster
Message 58 of 68
3DAli
Thanks Mark, well this might be helpful since I am using a different folder for my template as well. I will try to copy them over to the default location and see what happens, if this fixes it , then we now the reason at least!
Message 59 of 68
I would rather pull teeth than do a fresh Inventor installation.
If every solution to a problem is to do a fresh installation, clearly the product is not up to scratch.
Message 60 of 68
By the way; I tried putting the template back in the default location, pointed the project back to default location, went through the whole update rigmarole once again, opened a new part, same same...
