@Sofia.Xanthopoulou wrote:
Hm...., I do not get this message and I can update. After that, the template works fine.
@mcgyvr you could not update, too?
@Mark.Lancaster have you tried?
My installation is Inventor 2017.3, Win7. What differences do we have?
You might consider to reset Inventor.
Regards
@Sofia.Xanthopoulou I'm 2017.3 Windows 10..
Screencast..
Personally I think there is a nasty bug that has been around since 2013 related to this.. (and those that aren't using the out of the box default autodesk material/appearance libraries)
Notice also that after I create a new file from that template and then go to the update again that a "Color" style is also showing up...
That "color" style was NOT there when I had the template itself opened and did the update.. (BUT.. It would show when I changed "compare materials" to use my appearance library vs my material library)..
I've had this problem for years with colors/materials getting STUCK in my files and I cannot delete them even though they are not used.. But I don't want to take away from 3DAli here so I may continue that issue in another post..
