Style and Standard Editor
b11502179
b11502179
Hi. I would like to change 3 things:
1. default standard (ISO) > Projection View > Third Angle
2. Dimension > Default (ISO) > Units > decimal marker > comma , and display > leading zeros
3. Dimension > Default (ISO) > Displays > A: Extension, and B: Original Offset.
But for some reason, my inventor's style editor doesn't have the above options. It only has "Lighting" and "Texts" to choose from (screenshot attached below). Does anyone know what I can do? Please? It's been bugging me a lot to have to change these stuffs manually every time... Thank you very much.
kacper.suchomski
Hi
Open drawing file.
Kacper Suchomski
James_Willo
Hi, as Kacper says, you are looking at styles for 3D which typically is only lighting and text, you need to look at the style library with a drawing file open.
James W
Inventor UX Designer
b11502179
Omg you're right! Thank you so much!
b11502179
Thank you so much for your help!!!
