Inventor Forum
Style and Customize
3 REPLIES 3
justinpcaris
271 Views, 3 Replies
Style and Customize
justinpcaris
I am using Factory Design Suite 2013 and for some reason Inventor never holds my preferences for Syle and Customize tabs.  Every time I open inventor I have to import the preferences that I want to use and I am wondering why it doesnt save them as the new default.
Style and Customize
3 REPLIES 3
mpatchus
in reply to: justinpcaris
mpatchus
Your styles are probably set to read only within your project file, so in a sense, you are simply doing an override each time.
Bring up your project file and make sure your styles are set to Read/Write.
After setting the styles the way you desire, make sure to SAVE the styles (on the Manage tab).
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Inventor 2025 Beta
justinpcaris
in reply to: mpatchus
justinpcaris
I have the Use Style Library set to Read-Writte, is there another spot that I need to set it to Read-Write
mpatchus
mpatchus
That should be all you need.  Just make sure to Save your styles after you make changes.
(If you have saved parts that already contained the styles you want to use, open the part and then save the styles.)
Inventor 2025 Beta
Inventor 2025 Beta
