Student template creation - surface symbol
samuel.debruyn
Message 1 of 9
samuel.debruyn
Hi everyone,
I'm currently creating Inventor drawing templates for our students, and I'm having an issue with the Surface Texture Symbol standard.
I would like to force the template to use DIN ISO 21920-1:2021 for surface texture symbols.
As shown in my screenshot, on my PC only my "copy" of the settings is listed as being in use, and everything works as expected. However, it seems that this setting is stored locally rather than being fully embedded in the drawing template.
When I open the exact same template on a student's PC, two standards are listed as "In Use", and I can't seem to force the template to use only the desired DIN ISO 21920-1:2021 standard.
Is there a way to store/define this setting directly in the Inventor drawing template so that every PC using the template automatically uses the same Surface Texture Symbol standard?
Thanks in advance for any help!
Replies (8)
Message 2 of 9
admaiora
Inventor stores styles both locally within the document and externally in the centralized Style Library.
You will have the same issue with dimension styles and other styles as well.
Look here
Using the Save button, you can overwrite the centralized style. As long as Save is available...
If it isn’t, check here (Project Settings) and set Read-Write
In the template you will see this now:
Click save and you can choose what save
It recognizes what you have changed and what differs from the centralized style
For example
Let me know
Admaiora
_____________________________________________________________________________
Message 3 of 9
samuel.debruyn
Do I understand you correctly, that there is no "plug and play" solution for this, that students always have to "overwrite" their centralized style library?
Message 4 of 9
admaiora
The styles are saved here:
C:\Users\Public\Documents\Autodesk\Inventor 2026\Design Data
in XML format. Once the templates are set up correctly, all your preferences will be retained.
Admaiora
Message 5 of 9
CCarreiras
No...
You can have all that locally in the template, but you must have the read/write active to really save it in the template, if not, you will only have those edits in the file you're working (not even in your local template: if you close the template and open it again, your changes are not there, right?).
CCarreiras
Message 6 of 9
hollypapp65
Create a new Standard or rename one.  Put all your change in that Standard.  Rename all the Styles.  Save it in the template and set it as default.
This will remove all Style conflict because it's a new standard and style.
Message 7 of 9
lauri_barnhart
Welcome to the community, @samuel.debruyn.
Thank you for posting your question. Following up to see if the information provided by admaiora, CCarreiras or hollypapp65 clarified your question. If any of the posts provided the clarification you needed to resolve your question, please consider clicking on the 'Accept Solution' button on the post(s) that provided the help.
Best,
Lauri | Community Manager
Message 8 of 9
samuel.debruyn
I've spent the last days, trying the suggested solutions, but none of them work.
You mentioned creating new styles, isn't that what I already tried?
once I open the template from any other Pc, all the changes (dimension parameters, surface standard,...) all is jumping back to the "default DIN" of the "DIN template" which was used as a base for my personalized template.
But when I open the document settings, it shows my "standard" as the active one for the annotations.
Message 9 of 9
Paul-Mason
Did you copy your new template to theses other machines ?
In the example show below, my default is set to "METRIC"as indicated by the  BLUE box with BOLD.   If you yours is showing like this then all you need to do is set your NEW defaults styles the current then save the template agin
Inventor 2027 Pro
HP Z4 G4 workstation
Xeon Processor Intel(R) Core(TM) i9-9920X CPU @ 3.50GHz (3.50 GHz)
Memory 128 GB (128 GB usable)
Graphics Card NVIDIA Quadro P4000 (8 GB)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group and myself
