@l.leuce thanks for supplying the parts. What @JDMather was mentioning about the Frame Generator is what I was initially getting at.
If you can read up about how to publish structural shapes and see if it makes sense and report back.
The issue is that you might have to take a different approach to your design for the frame generator to be useful, but should pay off in the long run.
It sounds like you have a treasure trove of designs already made and probably parametric driven by some table, so recreating it all is probably not high on your list of things to do.
The positive is that if you create it with Frame Generator it will be easy to create rectangles that your custom channel sweeps around. Once you have the parameters and relationships setup it would be easy to change sizes and setup/run analysis.
Probably not the news you were looking for but in order to use the analysis functions some things have to be designed in a specific way.
Please select the Accept as Solution button if a post solves your issue or answers your question.
