Stress Analysis
Stress Analysis
I am trying to make a stress analysis of my model wing design to find the maximum deflection when a force of 300g is applied at the tip of the wing. I set my constraints, my moment and the material of my wing, but in the results, I can't find anywhere the total vertical displacement of the wing. Please help.
blair
Use the Probe for the one screen or use the report. The Bar graph is also giving you the max displacement which is the deflection of the wingtip.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
I am getting a measurement in the order of 0.5mm using the probe labels were as I should be getting something in the order of 300mm
blair
Post the model along with where you are applying or want to your loads and constraints.
Delta Tau Chi ΔΤΧ
