I was wondering, im doing stress analysis in autodesk inventor on my parts and when i check displacement results and display them in colours with legend it says that there is max 0.01024 mm displacement but on the screen where i see actual part it looks like it moved for 6mm from original location.
Is it normal or im reading something wrong?
Solved by CCarreiras. Go to Solution.
Hi!!
It's only a display option to help the user see better the tendency of part's deformation, mainly if we are talking about very small deformations like you have now..
You can go to the display tab and you can choose the "actual" option and you will get the real deformation in the model, or you can choose a bigger scale also to see better the def. tendency. See the image in attach. The important is the analysis's values 🙂
Regards.
