Stress Analysis - Cannot run analysis
matthewlenehan542
matthewlenehan542
Hi, Working on Inventor Professional 2023. I can create a study on a part or assembly and assign loads and constraints etc. but when I hit the "Simulate" in the ribbon, nothing happens. Not even a loading symbol on my cursor. Not sure how to fix this or what the issue even is.
I am sure I have set up the FEA correctly as I have replicated on another pc and it worked fine. Analysis occasionally runs in the "Frame Generator" tool on this device, but outside of that it does not.
Thanks in advance!!
johnsonshiue
Hi Matthew,
This could be environment related or user profile related. A few things to check. Please make sure all critical Windows updates are installed and the graphics driver is updated. Clean up %temp%. Then right-click on Inventor desktop icon -> Properties -> Compatibility -> check "Run as Admin."
Does it work now?
Many thanks!
Software Test Engineer
