I have been using the Stress Analysis Environment to do a large number of analyses on a model that has a multiple constraints (10+). I frequently need to suppress and unsuppress particular constraints to model different conditions, however this process is made quite tiresome as the software doesn't let me select multiple active constraints at once from the tree; I have to select each constraint one at a time and suppress from the right-click menu (weirdly I can multi-select suppressed constraints, just not active ones). For operations on sets of other objects e.g. deleting or suppressing several loads or contacts, I can multi-select, just not with constraints. Is this normal behaviour?? Seems like a bug.
For info I need to have multiple separate constraints defined to allow extraction of reaction loads at their specific locations. I can't roll them all into one.
Solved by johnsonshiue. Go to Solution.
Hi, sorry, there is no workaround for that.
(Nastran doesn't have that issue)
Admaiora
Hi Folks,
It does seem like a limitation at the moment. I will work with the project team to see what options we may have.
Many thanks!
