Stock Number is not an available property to add to the Parts List in my drawing. It was there in version 2024 and before. I thought maybe it was a bug so just updated and it's still not available.
Solved by johnsonshiue. Go to Solution.
Hi, I saw other posts about this bug. Maybe try to change your part list style for a default one then duplicate/edit as your current part list.
I'm assuming you are referring to 2025 then?
This works fine for me, can you upload a drawing please that shows this behaviour?
Hi! Open the idw/dwg file (and also the template file). Go to Style Editor -> PartsList -> check the style. Maybe "STOCK NUMBER" column had been renamed.
Many thanks!
I went to the parts list column chooser through those steps, and Stock Number was an available property. 🤔
Thank you!
