STL to IPT to STEP conversion
Hello all,
I received an exported STL file which was originally made in Rhino and I was able to open it in Autodesk 2019 and make it into IPT. However, when I try to export as STP, it saves no data.
Please, I need help with this because this isn't a large STL file at all (6MB) and I have a 8GB RAM laptop so memory shouldn't be an issue here (if it ever was one). My ultimate goal is to get a STP out of this file.
I tried SolidWorks but that is acting out worse than Inventor.
File attached below.
JDMather
Do you realize that stl is generally worthless for anything other than 3D printing?
AutodeskMeshEnabler
@JDMather I tried using a IGES file but it was stuck at 95%.
@JDMather I was able to make it into IPT but is it not possible that it would be able to save as STP since (I hope) it's not a graphics body?
mcgyvr
You need to install/use Mesh Enabler..
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=6950391119076900441&appLang=en&os=Win64
Install that.. Open your stl.. Convert to base feature... Export as step..
@mcgyvr Thanks. Will try out and update.
lena.talkhina
Hello @Anonymous !
Did a suggested app helped to find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
