.stl files exported from inventor not correct scale
Message 1 of 8
So im not too smart with cad, but when I go to 3d print a .stl file I exported it doesn't print the right size. Am I using the wrong file type, or is there something else I'm missing?
Replies (7)
Message 2 of 8
johnsonshiue
 Hi Ryan,
STL file itself is unitless. You need to make sure the Inventor export unit is in sync with your printer unit. I assume your printer is mm based. When you export to STL in Inventor, click on Options button in the dialog -> change unit to mm.
Many thanks!
Software Test Engineer
Message 3 of 8
Thank you so much! Im going to just go ahead and say this is right but ill be confirming tomorrow
Message 4 of 8
This answer is incorrect.  The .stl file is still way to small as compared to the original file.  Does anybody else have any ideas.
Message 5 of 8
JDMather
@Anonymous wrote:
.. Does anybody else have any ideas.
Here is an idea - Attach your *.ipt file here and I will demonstrate how to get correct size stl.
Message 6 of 8
johnsonshiue
Hi! I think the STL file was either exported in inch or cm. When you import it to Inventor, make sure you select "inch" or "cm" in Options dialog (Import or Open -> Options).
Many thanks!
Message 7 of 8
deleted
Message 8 of 8
Thank you, changing the units to mm worked for me
