@johnsonshiue wrote:
Hi! I think you misunderstood my reply. STL is unitless. But, the actual size depends on what document unit you exported from. For example, if you have a 1mmx1mmx1mm cube and you export it as STL (in mm), you will get mesh in 1x1x1 (unit free). Now, if you import it to an inch part file in Inventor, the mesh will become 1inx1inx1in, which is 25.4 times bigger than the original mm cube. Does it make sense? If you are still in doubt, please attach an example here. Forum experts should be able to guide you through the process.
Many thanks!
Thank you @johnsonshiue
I understand what your saying in this reply, but in my case I am creating an stl from a file that in inches and importing to a file that's in inches. it would seem that the stl file (though should be unit less) is in mm as it then imports and measures 114.3 inches and the measurement is the native file is exactly 4.5" (114.3/25.4=4.5")
I was able to solve this issue using exactly what I replied to you with. That is using options I was able to select units as mm for the import process, then went to tools - document setting - Units and changed it to "inch" now what was measuring 114.3inches was now measuring 114.3mm and once the units were changed back to inch is now measuring 4.5"
