1) is there a library or a parametric part?
2) Grabcad has a parametric part in nx format, but loading it into Inventor results in loss of all "parametricness" and so its useless since it is only a single size.
3) How to draw one seems daunting to get it to work right... thoughts?
Solved by mcgyvr. Go to Solution.
Hello, thanks for posting!
It may help the experts here if you attached a picture of what you are trying to create, as not everyone will know what this clamp looks like. Do you have a catalog with information on various sizes which could be used to create an ipart?
Also what version of Inventor are you using to model this? Thanks!
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
https://www.mcmaster.com/ear-hose-clamps/
3d step files available for most if not all sizes there..
