Hi everyone, first time poster here.
I have used Inventor for about 10 years now, mainly simple machine parts and cast/molded parts but haven't worked using surfaces at all.
I received a step model from an industrial designer for a new housing design. The solid model has some challenging transitions between different surfaces, and I don't know if I can replicate it myself, I'm still working on it. I first tried using the step model trying to get it ready for injection molding. The solid has been shelled already, but the thickness is not enough. Using Inventor thicken tool, works only on a couple surfaces but not all. I also filled in the imported model and tried the shell tool myself, but this also doesn't work at all.
Does anyone have an idea? What do you normally do in a situation like this? Remake the model from scratch in Inventor or try to work around the imported model?
