STEP file import - identify identical parts
I've got a STEP file from my client and the file is an assembly that has been saved as a single part. When I make components of this STEP file, I get parts base1, base2 .... base400 (for example). Each separate instance of the same part is a new part (e.g. base237). Is it possible to identify same parts (with the same geometry) and substitute them with a single part instead? So that I get 20 parts that repeat, instead of 400 new parts, many of which are identical (there are many bolts, nuts and washers, for example).
My client does not have an access to save STEP file in different format (because it would be a long and complicated route to trace the original author of the file through the network of subcontractors.)
Thank you.
jhackney1972
Probably not.  A base component does not have an dimensional features to compare.  You are going to have to do it manually.  I would suggest eliminating all the fastener bodies and then work with the other parts.  Fasteners can be added later.
John Hackney, Retired
johnsonshiue
Hi! Indeed, there isn't an automated way to do that at the moment. I would simply hide all the solid bodies and then unhide anything not nuts and bolts.
There is a semi-automated way though. Try this workflow and see if it works for you.
1) Open the multi-solid body part.
2) Go to Manage -> Make Components -> select all bodies and push them into individual parts. You will get 400 unique parts in an assembly.
3) Go to the assembly -> Manage -> Update Mass -> BOM.
4) Add Mass as a column to the BOM table.
5) Sort the Mass column. You should be able to see the parts with the same mass. Usually they are the same occurrences.
Many thanks!
Software Test Engineer
Thank you very much, this mass comparison solution is better than having to find every occurance and compare it to one another by measuring dimensions.
LukeDavenport
Hi technolog,
If this is still an issue for you, there is now an automated solution for this. See the Duplicate Replacer app.
https://youtu.be/sbFZaeBHehY
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
