Inventor Forum
Square pipes
2 REPLIES 2
2511028MSAE
254 Views, 2 Replies
Square pipes
How to correctly model a square pipe as in the photo, but with the appropriate tip? I use sweep but I can't select the end profile and without the end profile my pipe rotates. I also tried the Loft function, but it didn't work.
Tags (1)
Labels (2)
2 REPLIES 2
JDMather
in reply to: 2511028MSAE
@2511028MSAE
Attach your file(s) here.
johnsonshiue
Hi! The issue is with the sharp corner. Sweep can only keep the profile normal to the path or parallel to the path. In such sharp corner, it has to rotate itself to maintain the profile orientation relative to the path. You will either need to round the corner.
Many thanks!
Software Test Engineer
Technology Administrators
