If you're absolutely certain that you will never need to make any edits to the orphaned part, I guess there is no problem with having a dumb solid in your assembly.  I would never knowingly do such a thing-- I'm never that certain of a design until it's shipped and in service, and even then the customer may request modifications to the design at a some later point.
Having a master model controlling your design (in this case just two parts of it) is not an "outside" change-- it's the defining file.  It doesn't end up as a component in the assembly, but it drives two components (or more if you decide to incorporate more of your design in the master).  Many designers use this technique to drive the entire design of smaller assemblies-- all design changes happen in the master model and the parts follow.  I prefer this method whenever possible.
If you are interested, and are allowed to post a small assembly here, I'd be happy to show you how this might work for you.  I note that you haven't yet told us what version of Inventor you're using.
Sam B
Inventor Pro 2024.2 | Windows 10 Home 22H2
