I would like to know how to take a solid body and through splitting and extruded cuts turn it into multiple bodies. this is very easy to do in solidworks. I use inventor because for mold design it is more robust and when doing cavity/core functions i can retain the toolbody. that is a life saver. many times though i will need to split a part across a plane but only seperate a couple details. in solidworks you can select which features get cut and which ones don't and you also have the option of combining features together after a cut. The easiest example i could give would be that if i take rectangular block and cut a ring though it i will be left with a block that as a hole in it and also a cylinder inside of that hole. In solidworks this would automatically be turned into 2 solids. In Inventor it will still be counted as a single solid.
Please keep in mind that this was a simple example and so i don't need to be told how to extrude a hole and redraw the pin as a new solid. There are many instances where i create a cavity and then need to turn certain areas into core pins with that feature and so in solidworks i just do a circular split through the block and now i have a new solid with that feature on it. So, the actual question is; can Inventor do this or not? currently I just export my block, fix it in solidworks and then re open in Inventor. The pic i included is an example of a detail that i extruded a ring through to turn one of the details into a pin. unfortunately it is still being seen by inventor as 1 body when it clearly should be 2 seperate bodies.
