12:06 AM
- Mute
- Permalink
- Report
Hey Guys,
I have a question regarding this post...
https://forums.autodesk.com/t5/inventor-forum/creating-2-solids-from-lofted-flange/td-p/7352036
If I follow the method provided in the solution (Post 6), copy the object as a surface, delete faces and then sculpt, is there a way to make the two solid bodies still parametric with one another?
As it is now, if I need to go back and change some dimensions, they will only apply to the original solid body and not the new sculpted body if that makes sense?
Any help would be appreciated
Thanks!!!
