Split does not allow face to be used as tool
SEC_MECH
SEC_MECH
I think that I should be able to use a face as the split tool but SPLIT only allows me to select a plane as the tool.
SPLIT instruction here at step 4 say "Select a 2D sketch, 3D sketch, work plane, or surface to be used as the Split Tool."
Here is the behaviour that I see in Inventor 2022
Am I correct that I should be able to use a face for the split tool. If so, why won't Inventor allow me to select a face?
SharkDesign
Are you using a surface or a solid body face?
You need to create a sketch line, extrude that as a surface and use that as the tool.
  Inventor Certified Professional
johnsonshiue
Hi Folks,
Just a minor correction. You don't need to extrude a sketch as a surface to split a face. You can select a 2D or 3D curve as a split tool. As a split tool, a 2D sketch will split the face in sketch normal direction. For 3D sketch, the curve has to be lying on top of the face.
Many thanks!
Software Test Engineer
SEC_MECH
It would be useful if I could select a flat face as my tool so that I don't need to create a new plane on that face just to perform a split. I think I will suggest this as an improvement.
EDIT - It was already there https://forums.autodesk.com/t5/inventor-ideas/split-command/idi-p/5329787
