Split body without using surface/planes?
adamsangala
adamsangala
so I have a file (imported from .stp) which is represented as one body, but in reality, it should be multiple bodies. Something like this:
Is there any way to split this body into three separate bodies withou manually spliting them using surfaces/planes?
Thaank you.
CCarreiras
HI!
You can use a simple sketch for this case.
BTW
  • you have to use split tool, to have a multisolid.
  • If you need to have 3 different parts, create more two copies from that file and delete the solids you don't need in each file (use Delete Tool, or Direct Tool).
CCarreiras
adamsangala
Unfortunately real filenis much more complex. Idea which I was trying to convey was, that those objects are not connected.
I was hoping that there is some clever iLogic rule to do this.
kacper.suchomski
Are you sure you can't select any import option to create an assembly, or at least a multi-body part?
Can you show this file?
Kacper Suchomski
adamsangala
yes, unfortunately I am positive about that 😞
I am sorry but I cannot share this file. I hope you can understand.
kacper.suchomski
Try a few options:
  1. Open/import a step from the home screen
  2. Import file inside part file (3D model / create / import)
  3. Import file inside assembly file (insert cad)
When in different environments, check both the import and insert options.
Search the dialogs thoroughly each time.
Kacper Suchomski
johnsonshiue
Hi! This is about turning disjoint lumps into separate solid bodies. There is an awkward workflow to do that. Create a Rectangular Pattern -> Whole Body -> Create New Body -> number of instances = number of disjoint lumps -> distance = 0.
Then you will have identical bodies on top of each other. Keep one visible and the rest invisible. Use Delete Face -> Lump selection -> select the unwanted lumps. Repeat the process for other bodies.
Many thanks!
Software Test Engineer
