Inventor Forum
Split a body into multiple parts...
3 REPLIES 3
RDG3PO
2794 Views, 3 Replies
Hi all,
I have an insert that I'd like to split into several layers. Is it possible to do this with the split tool, or is it limited to only one "split tool" at a time?
In the picture, the wireframe is the 'insert', the letters indicative of cavities cut into the insert. The purple sketch lines would be typical of where the solid part would be split into multiple parts.
INVENTOR 2014 STANDARD
IOSX and PARALLELS
Tags (1)
3 REPLIES 3
JDMather
in reply to: RDG3PO
You can split the part as many times as needed, but need a separate Split Feature-New Solid for each.
RDG3PO
in reply to: JDMather
That's what I was afraid of. Makes the model tree a little more cluttered.
Is there a way to suggest this as a feature, to cut using multiple split lines?
IOSX and PARALLELS
Curtis_Waguespack
in reply to: RDG3PO
Hi meatcircus,
You can share your ideas about how to improve Inventor with the Development Team at thsi link:
http://forums.autodesk.com/t5/Inventor-IdeaStation/idb-p/v1232
I hope this helps.
Curtis
Technology Administrators
