Inventor Forum
Spline Locked
4 REPLIES 4
917 Views, 4 Replies
Spline Locked
Hello everyone
I am sorry if my question is too simple, but I really don't understand how to solve it.
I am trying to redesign a simple mouse based on Soli*works tutorial https://youtu.be/lnJTfrqYfMU?t=125
I am new in the spline. I can't do exactly as he did
this is what he did
this one is mine
I don't really know why I can't move the red square. I want to lengthen it so I can get a better curve, but I can't. I have open "show all constraint", but there's no constraint
I just make a constraint to X and Y axis.
when I try to lengthen it, the overconstrained error pop up
one more thing, what are 130 and 115 mean in his tutorial? how can I do that in Inventor?
I try to measure the dimension but the dimension shows the length of the square.
**I use Autodesk inventor 2020 student version
thank you so much
4 REPLIES 4
JDMather
Have you Activated that Handle?
Attach your file here.
in reply to: JDMather
@JDMather Hi, thank you so much for your help
here I attached the file.
I have activated the handle, I constrained the handle into X axis/Y axis, but when I add the dimension
it is always said "overconstrained", I can't do constrained axis, add dimension and adjust the handlebar in the same time
by the way, what is the 130 and 105 in inventor?
thank you so much
JDMather
I think the fact that you are not able to drag the handles in Inventor 2020 is a bug - it would make it easier as the spline handle weight formula for Inventor does not match SolidWorks, so you have to go by trial and error.
The weight dimensions are added in a different technique than SolidWorks - simply select anywhere on the Handle.
Note that the weight dimensions are ul (unitless).
Open the Attached file.
Make the SWx sketch visible.
I dimensioned the handles to approximate the spline in the SolidWorks image.
Hi, thank you so much for your reply @JDMather
it is really help me,
