Spline Curve rough when exporting to PDF
knut.c.bunge
Message 1 of 9
knut.c.bunge
Inventor Version: 2021
I have a problem, where when I try to export a drawing to PDF the spline curves I draw look bad (See attachment).
Does anyone know a fix for thix?  On the left its the PDF on the right is the drawing in Inventor.
Replies (8)
Message 2 of 9
SharkDesign
Was going to suggest changing the resolution, but doubt it will fix that.
  Inventor Certified Professional
Message 3 of 9
knut.c.bunge
Already tried. But thanks for reply.
Message 4 of 9
johnsonshiue
Hi Knut,
If possible, please share the Inventor files (idw/dwg, ipt, and iam). I would like to take a look at the behavior and understand it better.
Many thanks!
Software Test Engineer
Message 5 of 9
knut.c.bunge
I have attached a set of files showing the problem.
Thanks in advance.
Message 6 of 9
johnsonshiue
Hi Knute,
Many thanks for sharing the files! I can reproduce it now. It looks like the sketch spline is interpolated using very loose tolerance to boost performance. I need to work with the project team and see what we can do about it.
Thanks again!
Message 7 of 9
michael_marx
Hi Johnson,
problem still exists in 2025.1
Is something on the roadmap to improve this behaviour?
thanks
Michael
Message 8 of 9
johnsonshiue
Hi Michael,
Unfortunately, I am not aware of a good solution. The issue here is that the better spline export quality would come at the expense of the file size and the capacity.
Many thanks!
Message 9 of 9
j.muehl
Same problem here
