Inventor Forum
Spiral-Helix in sheet metal
8 REPLIES 8
Message 1 of 9
dvandekuyt
1558 Views, 8 Replies
Hello All,
Need a little help. Trying to create a partial (80 degrees) spiral helix sheet metal pattern. I can generate the spiral helix model but cannot create a flat pattern.
I have tried using the COIL command but IV2010 complains that there is no solid body found to unfold. (Please see attached .jpg)
I have tried almost everything else I can think of.
Any help would be greatly appreciated.
DV
8 REPLIES 8
Message 2 of 9
dvandekuyt
in reply to: dvandekuyt
Hello All,
DV
Message 3 of 9
johnsonshiue
Hi! Based on the image you attached, it looks like you did not create the coil feature. As a result, flat pattern fails. Could you post the file here or send it to me?
Thanks!
johnson.shiue@autodesk.com
Software Test Engineer
Message 4 of 9
Sweep a line as a surface, then thicken - Post your part for help
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr. Tel. (260) 399-6615
AIP 2008 SP3, AIP 2009-SP2, IV2010 ProPcCillin AV
AMD 64 x2 3.0 Ghz, 8GB RAM GeForce 9800GT 512MB
XP Pro SP3, XP Pro64 SP2, Windows XP Silver Theme
http://teknigroup.com
Message 5 of 9
dvandekuyt
Johnson,
Thanks for your resonse. Please find attached my attempt.
Thanks!
Derek
Message 6 of 9
dvandekuyt
Dennis,
Thanks for your response. Please find attached my attempt.
Derek
Message 7 of 9
johnsonshiue
Hi! Inventor does not support unfolding helical face. However, if you change the thickness to 19in, flat pattern will compute. It is because the inner face and outer face are analytical. But, I do not think the flat patterning process is consistent with your design intent.
Thanks!
Message 8 of 9
S_May
Message 9 of 9
S_May
