- Mute
- Permalink
- Report
Hi everyone,
I'm trying to design a piece that includes a spiral structure. I managed to create the spiral with the "coils" tool (Fig. 2) as well as with the "sweeping" tool (Fig. 1). But with both I have the issue that the surface of the spiral is not smooth but has a stairs-like surface. The height of these stairs depends on the dimensions of the spiral. Also when I export the parts to stl-format the stairs-like surface remains.
I am sure that this effect is not just optical as I can select the edges as it can be seen in figure 1. This works at least in the stl-file. In the ipt-file I cannot select the edges.
Is there any option to generate a smooth surface? Or is there a limit on how small the details in an inventor part can be? It would surprise me if this is the case as the middle pole has a diameter of 0.8 mm and therefore the steps have a height of around 0.2 mm which is not exessively small.
In case this is a normal behaviour and there is no setting to get a smooth surface is there a workaround to circumvent that problem?
Fig. 1: spiral generated with sweep function.
Fig. 2: Spiral generated with coil function.
Thank you in advance for your help.
Kind regards,
Dennis
