I just loaded SP2 last week,... is it my imagination, or did the Vault time out issue, which was fixed in SP1, return in SP2? How can I remove a service pack, and go back to the previous one? It's very annoying to have this issue return.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by rdyson. Go to Solution.
Hello cbenner,
What's products' SP2 you have patached last week? Inventor 2011 or some other products?
Could you please share the reproducible steps for this issue you mentioned?
Helen
Inventor Pro 2011. On the initial release out of the box, Vault login times out after approx. 15 minutes, and you lose connection to Content Center, as well as for checking in/out files. This was fixed with SP1, the timeout issues no longer occurred, and once logged into Vault, you stayed logged in for the duration of your session. The day I posted this, I applied SP2, and shortly after noticed that Vault connection times out once again as it did prior to SP1. Simplest solution for me woul be to remove SP2.... can this be done without re-installing Inventor and losing all of my settings?
Chris Benner
Opps, I am sorry that I misunderstood you were asking how to remove the SP2... Thanks rdyson for the sharing.
As for the issue you mentioned reproduced in SP2 again while not in SP1, I have forwarded this post to corresponded team for investigating, sorry for about this inconvenience and thank you for your patient.
Helen
