Inventor Forum
Solids to surface
3 REPLIES 3
1499 Views, 3 Replies
Solids to surface
I need to convert an assembly of solids to a surface model, containing only centered faces. E.g a plate with thickness of 20mm needs to be represented only with an eqal sized face with thickness 0 in center of the former plate.
Is there a solution for this problem?
A
Tags (3)
3 REPLIES 3
JDMather
Two ways
Find Thin Bodies and/or Midsurface is the easiest.
Midplane Shell
or Offset Surface
swalton
I know that the FEA module in Inventor Pro can flatten plates to 2D mid-planes for analysis, but I don't think there is a way to export them for use in other software.
I expect you will have to use several manual operations to make and export what you need.
I think you can make a surface in the parent part and derive it but not the solid body into a new part.  You may have to make a new assembly with the surface parts.
Steve Walton
Inventor 2025
Vault Professional 2025
in reply to: JDMather
Thank you!
Midsurface worked out just fine. If there only was a way to export the thinned model:( Is that excluded in the 2017 Inventor version?
Anders
